configure eaps shared-port segment-timers health-interval
configure eaps shared-port port segment-timers health-interval seconds
Description
Configures the shared-port health interval timeout.
Syntax Description
port Specifies the port number of the common link port.
seconds Specifies the amount of health interval, in seconds.
Default
N/A.
Usage Guidelines
This command allows you to configure the length of the shared-port health interval timeout, in seconds, for a given port.
The following command configures a shared-port health interval timeout of 10 seconds on port 1:1.
configure eaps shared-port 1:1 segment-timers health-interval 10
Platform Availability
This command is available on all platforms with the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and what licenses are appropriate for this feature, see the Switch Engine v33.1.1 Licensing Guide document.
